Et dans le use , ou sa se trouve et sa vaut combien environ chaques ?
et j'ai le seal ou le cardans avant droit rentre dans la transmission qui coule .. quelqu'un aurais le numero de pièces ou un lien pour le trouvé ?
![Thumbs Up :thumbsup:](./images/smilies/thumbs_up.gif)
http://forums.nasioc.com/forums/showthr ... ?t=1772793Front Axle:
Female Axles- Held in by a roll pin tht has to be tapped out to slide axle off of transmission stub.
Male Axles- Held in by retainer clip on the diff side of the axle. They have to be "popped" out of the front diff for removal.
If you choose a male axle 6mt and you have a female front axle car you will need these:
806730042 Oil Seal LH x1
806730041 Oil Seal RH x1
38415AA110 Axle Stub x2
805329010 C-Clip x2
If you have a Female 6mt and a male front axle car you will need the following:
806735230 Oil Seal x1
806735240 Oil Seal x1
