coil spring
coil spring
Jhesite entre deux cie...cobb ou tanabe??? Que me conseiller vous???
Re: coil spring
quelle voiture, année?
VENDU: Saabaru 92x Aero 2005
- vhot_001
Re: coil spring
Quelle application aussi !?
Re: coil spring
STI2010 hatchback...daily drive
Re: coil spring
Go with RCE Yellow.. I have them and they are really worth the money. Just DON'T go to Swap Shop to have them installed, they didn't install the front bump stops that came with them, and my suspension is making creaking noises on the passenger rear. Poor install job!
Re: coil spring
Je sais que c'est pas dans ta liste mais je te suggère de vérifier aussi chez H&R, je n'ai que des bons commentaires sur leur springs!
- MARS1
Re: coil spring
danmcd17 a écrit :Go with RCE Yellow.. I have them and they are really worth the money. Just DON'T go to Swap Shop to have them installed, they didn't install the front bump stops that came with them, and my suspension is making creaking noises on the passenger rear. Poor install job!
1- Have you called 'em to ask why the bump stop was not replaced?
2- There is no relation between a bump stop and a creaking noise. Whatever noise you're hearing might be more related to bushings being more sollicited because of the drop then the suspension install.
Audi freak
