P0700
Guig'z
P0700
Message par Guig'z »
Subaru Outback 2010 3.6R
L'auto est tombé en Limp mode,
AT oil temp, check engine, cruise, frein a main allumée.
Je le scan, p0700; sa m'aide vraiment pas!
J'ai clearé et le probleme ne revient pas.
Dealer time?
Sent from my iPad using Tapatalk
92 SvX 5mt ;) (scrap)
Re: P0700
P0700 Subaru - Transmission Control System Malfunction
Possible causes
- Shorted or open circuit within Transmission Control Module (TCM)
- Faulty Transmission Control Module (TCM)
Since the P0700 is just and informative code, check the TCM for more codes to resolve the problem.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Driveability problems
- Transmission shifting problems
P0700 Subaru Description
The Transmission Control Module (TCM) monitors the malfunction of sensors and actuators relating to transmission control. When the TCM detects a malfunction with the control, a signal is send to the Engine Control Module (ECM) to trigger the Engine Light or Service Engine Soon light. The ECM stores the P0700 code and it means the TCM detected a malfunction with the transmission controls.
Guig'z
Re: P0700
Ouais sa je savais mais mon ELM327 ne rentre pas dans le TcM :(
Ma prendre conger et aller au dealer lundi!
Re: P0700
Guig'z a écrit :Ouais sa je savais mais mon ELM327 ne rentre pas dans le TcM :(
Tranny code = Subaru select monitor.
